We are sorry to hear this.
Please mention the Operating System of your computer.
Do you have any other AntiVirus or conflicting software in your computer?
Keep us posted.
I have removed all avg software by using uninstall program followed by running avg clear and removal.
Problem is now that after every restart of pc, the internet connection get lost after seconds.
As test I have installed avg again and problem was gone. Removing avg again and problem is back.
Wat should I do to get this solved?
Installation on windows 10.
Keep us posted.
Yes of course. The same procedure. Incl running avg clean and removal.
Thank you for writing back, J M
Do you get any warning message when the internet gets disconnected?
Are you experiencing the same issue in other devices?
I use windows10. And is use the windows10 antivirussoftware.
