Hi Alan,
We will help you in this.
It was a bug and our developers have fixed it by releasing an update (20.10)
Kindly check if your product is updated or not : AVG >> Menu >> Settings >> Update
If you are still facing this issue, kindly use clear from the below link and uninstall the AVG :
https://support.avg.com/SupportArticleView?urlname=Uninstall-AVG-software-Clear-Remover
Restart the PC and reinstall the AVG to fix this issue.
Every time I log on to my computer the Hacker Attack on my AVG is disabled. How can I stop this happening?
Hi Alan,
