Hello Ahamed,
We regret for the inconvenience caused. We would request you to run the Microsoft Visual C++ distributable file using the link provided below :
http://www.microsoft.com/en-us/download/details.aspx?id=30679
Once done please run the AVG remover tool to completely remove AVG and then re install it.
Hello,
Current Installation (AVG Protection Free) – Fails with the following message,
“The program can’t start because MSVCR110.dll is missing from your computer. Try reinstalling the program to fix the problem.”
When I try to reinstall I get the 0xE001D012 error,
Based on previous posts here I have tried to use the AVG removal tool, that too has failed with the following message,
“C:\Program Files (X86)\AVG\Av\avgclitx.dll is either not designed to run on Windows or it contains an error. Try reinstalling the program to fix the problem. Error status 0xc000012f”
Regards
Fazal
Fazal, If applicable… For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Ahamed,
