I am facing above problem during installation?
have anyone resolved this issue?
I am usig ave protection free version.
Thanks.
bhav.
I tried that. Again downloaded avg protection free and again in the last step of installation same error occured. There was no other antivirus installed or no previous avg program.
Thanks.
Hello Bhav,
We understand how something like this will try your patience.
Mostly this error is due to the previously installed AVG program or anyother Antivirus program installed on your system.
Is there any other Antivirus program or AVG program installed on your system? If so, please uninstall it and try to install AVG Program.
Hello Bhav,
We would request you to run AVG remover tool to completely remove AVG and then re install it.
Thanks.
Hello Bhav,
Bhav, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Thanks.
