Avg is blocking an incoming connection
Hi Linda,
From your description, we see that you've received the Brute force attack notification from AVG. SMB allows a remote connection to share files in a network.
Since the IP address listed in the notification is of your device in the same network, you can follow the steps below 'adding trusted connections' in this article to check if it helps.
Hi Linda,
03-31-2022 AVG is blocking an incoming connection from PC A (Win10) - to LapTop A (Win10) Both machines are on the same network, and both are using AVG PRO.
I regularly access files on my PC from my LapTop to work on them in the evening. On 03-30-2022, last night, I was blocked and blocked again this morning.
Threat name  SMB:BruteForce; Attacker IP  192.168.5.101; Process  System; Detected by  Remote Access Shield; Status  Connection blocked
