Thank you. With both the file and the path as two separate entries in the exception list I can now get Act tr run.
Thank you,
That has solved my problem. I appreciate the quick reply - Gary
You are welcome Graham. Glad to hear that your issue got fixed. Please feel free to contact us again should you need any further assistance. Thank you.
Hello Gary, pleased to know that the issue has been sorted out. Please feel free to contact us for any further assistance. Thank you.
I have been using ACT! with AVG for years. This last week, ACT! suddenly will not come up unless I temporarly disable AVG protection. I have tried reinstalling ACT! while AVG is deactivated and have made sure all the processess associated with ACT! are listed in the firewall Applications list to no avail. What else do you suggest I need to try in order to solve this problem.
Thank you - Gary in Nanaimo
Thank you,
Hello Gary, I understand how something like this can really try your patience. I am very sorry to hear that. I request you to add ACT in exception list, please review the below article http://avgread.me/18WB2dg . Please feel free to contact us back for any further assistance. Thank you.
Hello Graham. Please right click your ACT program and go to properties. You could see .exe file and folder path. Please use the link: http://avgread.me/18WB2dg to add .exe file in application/file exception list and path in folder exception list. In the part, Use this exception for: uncheck Resident Shield and Manual and Scheduled Scan. Only Identity Protection needs to be checked. Please feel free to contact us if you are facing any issue. Thank you.
