Hello Lanz,
We regret for the inconvenience caused. We would request you to run AVG remover tool to completely remove AVG and then re install it.
Hello Lanz,
Lanz, If applicable… For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
