Avg miniport driver problem
I have done that… it says it doesn't find any avg in the system.
This is strange… I have no internet.
Hello Eni,
We regret to hear about that. We request you to boot your PC to safe mode ( http://avgclick.me/rebootintosafemode ) and run the AVG remover tool there to uninstall AVG completely and then try to re install it.
Good morning.
After installed the AVG FREE, had no longer internet, because of MINIPORT DRIVER.
I tried to uninstall with AVG REMOVER, but no success… tried to reinstall again to remove after , but without internet it didn't work.
How can I solve this?
I have WIndows XP!
Hello Eni,
We are sorry to know that the issue persists. In this case, we suggest you to check if any other firewall is installed in computer. And let us know if you are using the wired or wireless connection?
Thank you
Hello Eni,
Thank you for the information. The Miniport need not be uninstalled. We suggest you to use the wired connection and check if you are able to access Internet and we also suggest you to check if the airplane mode is enabled in your computer, if it is enabled, please disable the same and check.
Hello Eni,
