I had this AVG Miniport issue on a desktop. Two AVG Miniport entires in the device manager that couldn't be uninstalled. The solution: I uninstalled the ethernet card, and the two miniport entries disappeared with it automatically. Then, scanned for hardwar changes and it installed the ethernet card perfectly, wihout the addition of the miniports. Looks like the AVG miniports driver had attached themselves to the eternet card driver in some way, which prevented them from being uninstalled individually on their own.
In my device manager, there is an entry avg miniport with a yellow mark. I have tried uninstalling, but cannot ( permission denied , may be required for computer boot)
I also tried updating the driver, but no result.
The crazy thing about this issue is that it is identified every time I run AVG PC Tune Up!
Any help appreciated as it seems AVG doesn't have any help on their webpage on this issue.
Hi Brian,
We regret to hear about the inconvenience caused, could you please share us a screenshot of the AVG interface from where you are facing issues, so that we can check and help you. Please click on the link to show how to create a screenshot : http://avgread.me/1aZxsAV
Also, please tell us the version of AVG you are using in your computer. Thank you.
Hello Brian,
Thank you for the screenshot. Have you optimized the computer with AVG PC Tuneup?If not please run the maintenance scan and optimize your PC.
Hi, if you read my first post, the AVG PC Tuneup identifies this as a problem, but no solution.
Everything else on my computer is fine.
Hello Brian,
We certainly understand your concern. We have sent you an email instruction to get connected with our technical support team. Please follow those instructions and you should be able to resolve your issue.
Hi Gunaseelan,
Version is 16.151.8012
