AVG not allowing connection to recaptcha
Hello Ray,
Is the issue persists with all sites/browser or with any particular sites/browser?
We'd suggest you temporarily disable AVG Internet Security and check for the issue status.
If the issue persists, please turn off AVG Secure VPN and check.
In addition, could you please share the screenshot of the message that says 'Recaptcha connection is not going through' to investigate further?
Refer to this article for the steps to capture the screenshot.
You can post the screenshot here on your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Why am I not being able to log into sites when I have to verify 'I am not a Robot'. I'm getting a message that the recaptcha connection is not going through. This seems to be just a recent problem. How do I resolve this. Cheers, Ray
Hello Ray,
