Avg not working
Hello Jocelyne,
We regret for the inconvenience caused.
We would request you to run AVG remover tool to completely remove AVG and then re install it.
3. After the restart,  manually delete the AVG Remover folder in the C drive of My computer.
my avg scan froze and it would not respond to stop san I tried to uninstall so I could reinstall and that could not be completed
Hello Jocelyne,
Jocelynel, If applicable…  For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
  1. Once uninstalled download the installation file using the link : http://www.avg.com/download to reinstall your AVG program.
