AVG on Surface Pro X
Hi James,
We're glad to help you with the info.
AVG can be used on
  • Windows 10 except Mobile and IoT Edition (32 or 64-bit); Windows 8/8.1 except RT and Starter Edition (32 or 64-bit); Windows 7 SP2 or later, any Edition (32 or 64-bit).
  • Windows fully compatible PC with Intel Pentium 4 / AMD Athlon 64 processor or above (must support SSE2 instructions); ARM-based devices are not supported.
Do any products run on Surface Pro X?
Hi James,
AVG can be used on
