I too, are having the same problems with AVG One Click Maintenance that apparently will not correct itself. It gets stuck on Windows Repair and now shows
14865 problems that don't get deleted and when I call AVG they tell me not to worry, that that is only numbers and the threats are really not there, but they are aware of the problems and we have await a future update to correct it. I find that answer unacceptable and know that they will fix it, if you pay them additional fees when you call them. I will not renew my subcriptions to AVG in November when they expire on my personal computer and business computers at work. I have been with AVG for sometime and I now believe most of it is SCAM.
Hello Robert. I really apologize for the inconvenience that you have faced. AVG believes in its customers and cares about their protection. I will make the resolution easy for you. I have sent you an email to fix this issue immediately. Please check your inbox and you will be just fine. Thank you.
