AVG PC Tune UP problems
Hi Gill,
This isn't the experience we want you to have.
AVG TuneUp allows us to revert changes made by it through the Rescue center.
The issue might have fixed if you made us as the initial contact when you experienced this issue.
If you re-consider, we can reinstall AVG TuneUp & check.
After installing Tune Up on my PC I could not access my Adobe programmes. I uninstalled the programme but then could not open lots of programmes including Word, Excel, InDesign. I used all your uninstall tools but in the end had to have a PC engineer repair the issues to my registry and system files that Tune Up had caused and left behind after the programme was removed. Basically Tune Up left behind a file in the registry that confused the programme into thinking that the file I was opening was not available. This cost me £60 as each file had to be removed manually as the 'clean up' programmes you supplied did not remove them. I also restored my PC to an earlier date and these rogue files still remained. and I am very unhappy that your product was the cause of this.
Hi Gill,
