Avg pc tune up will not start
Hello Peter,
We regret for the inconvenience caused. Could you please let us know whether you have installed the one day trial version of the AVG PC TuneUp program?
Peter, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
I recently loaded AVG  PC Cleanup.
I t worked once but then when I tried again it would not open.
I read your website where someone else  had a similar problem and the advice was to reinstall the program.
I tried that and it still does not work
I read on your website that  other people have the same problem even after re installation ,  and that  AVG provide remote online support to fix the issue
Please help
Hello Kishore,
re below.
I loaded AVG  on a 30 day trial.
30 day Pro Trial.
I have removed AVG PC tune 3 times and reinstalled it.
I see from your website my problem is common with other users.
Please advise what to do next ?
thanks
you emailed me to use uninstall tool… Messafe said
Please click this link http://aa-download.avg.com/filedir/util/AVG_Remover.exe to download and run the AVG Remover tool…
I trird to use this uninstall toll and got this message,
Zstate.exe system error
The program cant start becauseavgtopenssix.fmv.1.dll is missing from your computer. Try to reinstall this program to fix the problem.
how do I do this???
Hello Peter,
We regret the inconvenience caused .Could you please  provide us with the screenshot so that we could analyze the issue more better? Please follow the instructions on the article http://avgclick.me/getscreenshot to create the screenshot.
