AVG PC Tune Up won't let me activate using product key
Hello,
I have a regular annual subscription to AVG PC Tune Up, and usually I use the product key sent to me to activate my product. However, on my new laptop, I download PC Tune Up but there's no option for me to use my product key and activate my subscription. Instead, it keeps insisting that I buy the product, and there's no way for me to establish the fact that I have already bought it, and to use it! It will also say certain features are not available to me because of this (e.g. when I click 'Settings')
Please let me know what I can do. When I press Help, it just gives me a generic sort of help manual, without any option to register/activate, and just other options to open the AVG website and support site, About etc.
Hello Adrian,
We regret to hear about the inconvenience caused. It seems you have installed AVG TuneUp - Unlimited which is a different product. We suggest you to uninstall the AVG TuneUp - Unlimited from control panel and install AVG PC TuneUp.
Go to Start -> Control Panel.
Select AVG PC TuneUp in the list of programs.
Click the uninstall or Change/Remove button.
Select uninstall.
Restart your computer.
Please click on the link to install AVG PC TuneUp : http://avgread.me/1ERJxSd
Please, feel free to let us know if you require any further assistance. Thank you
Hello Adrian,
Select uninstall.
Hello Adrian,
Thank you for your reply and for your support of AVG products. We are happy to hear that you have installed and activated your AVG PC TuneUp successfully. It is customers like you that are helping to make AVG a household name.
Thank you for choosing an AVG solution for your computer.
Hi Gunaseelan,
Thanks for your quick reply. It works well now, and allowed me to enter my product key just fine! Thanks so much for your help :slight_smile:
