AVG PC Tuneup - Maintenance - System Cache & Logs
Hello Donna,
Do you have the trial or paid version of AVG PC Tuneup installed?
Do you have the latest 2016 version installed?
Did you check the scan immediately after the result or the next day?
Thank you for your help!
I just bought and downloaded the latest 2016 AVG Ultimate and it came with AVG PC Tuneup.
The System Cache & Logs never completely cleans even though it shows that "31 items cleaned".  When I run it again, the same items are still there.  Please help me with this.  Thank you.
Donna,
We understand your concern, we woudl like to inform you that, when we process any task or the background process may creates the temp/ cache files at each instant. Since, your computer is running for a while, that compuetr's backup and startup files will have the tendency to reoccur so everytime when you run a scan,  AVG will detect and remove them. It is recommended to run a scan twice or thrice in a day. Thank you!
Hello Donna,
