Hello Jean,
We have sent you an email with instructions to get additional support to fix this issue.
Hello,
Since I installed the latest Avg Pc tuneup update I get a lot of troubles.
Most of the applications were put in sleep mode.
I already contacted Avg support team and they tested and fixed online my avg pc tuneup software.
But afterwards I encounter again problems.
Because of the “sleep mode” some pps, pdf or even Windows Live mail doesn’t work correctly. Putting all of the applications out of sleep and…the problem is immediately fixed.
Putting everything in “sleep” isn’t the solution at my side. So what to do if I don’t know what is setting in “sleep” is causing the problem.
So I would like knowing how, before reinstalling, to remove “completely” Avg pctuneup
Thanks for helping.
Hello Jean,
