Hello Shady,
We request you to submit the ticket to our mobile team who can assist further on this matter.
Click on this link: https://support.avg.com/support_contact_form?l=&retUrl=support_sales .
Select the option as "YES" and the operating system as "ANDROID"
Fill in the details and click on the option "answer via email"
Once your request is submitted you will be getting the prompt answer via email from our mobile team.
Hello everyone,
It seems that after the recent update or two to the AVG Pro app on Sony devices, the call blocker no longer works. If I press the + button to add a number to block, the "from call log" option button is no longer there, and even if I enter a number manually, I'll still get calls from that number. Sony's stock call log shows some numbers with spaces between them, but I can't enter the same numbers into call blocker in those same formats (with spaces,) and so the call blocker fails to match the entered numbers with the undesirable incoming ones in the call log, and hence won't block them.
This has been going on since mid- to late January 2019. The issue is the same on my one Pie device and two Oreo devices.
Shady
Hello Shady,
