I bought a two-year subscription to AVG Pro in November 2015. But I keep getting pop ups telling me my trial expired and to buy the product. Meanwhile the program is not functioning.
Thank you for your prompt response. I'm struggling to make sense of it, though!
My account states that I am subscribed until November 2017 to AVG Performance PRO, which includes:
AVG PC TuneUp for PC: product info / user manual / download
AVG Cleaner PRO for Android: product info / download
AVG Cleaner for Mac: product info / download
But the TuneUp is not active and the pop-up states that my trial to AVG Pro has expired. It looks to me as if my subscription isn't working.
Hello Robert,
Thank you for replying us back. We would request you to run AVG remover tool to completely remove AVG and then re install it.
Note : Please install your AVG Antivirus program first and then try to install the AVG Performance program.
Hello Robert,
We understand how something like this can really try your patience.
Upon carefully reviewing your account, I see that you have purchased AVG Performance multidevice (2 years subscription) on November 2015. Please be informed that AVG Performance comes under AVG Zen product. AVG Zen has both AVG Protection and AVG Performance built in it. Since you have purchased only AVG Performance it will be active till 2017.11.27. And the trial version of AVG Protection will be installed in your pc. Once the trial version expires you need to purchase the full version.
Hello Robert,
Thanks, will try that
Robert, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
