AVG processes running after uninstalling
There are AVG processes running under windows 10 after uninstalling the software
What should I do cause windows will not end these?
Hi Michael,
We are sorry to know this.
We will check and help you with this issue.
We request you to run AVG clear followed by remover tool as mentioned in this article: https://www.avg.com/download-thank-you.php?product=REM to remove the AVG traces.
NOTE: If there are no AVG program found, click on "Run Anyway" to proceed with the removal.
Feel free to contact us if you need further help.
Hi Michael,
