Veronica, If applicable… For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Veronica,
We regret for the inconvenience caused.
We would request you to run AVG remover tool to completely remove AVG and then re install it.
Hi
I keep getting a pop up stating "The installation of this AVG Product is defective. Please install the AVG product again to correct the problem. (5)". I have been using this on my HP Pavillion for close to 12 months with no concerns? Do I need to re-install? Thanks in advance.
V
Hello Veronica,
