Hello Juan,
You may get the issue in the future since you have, you temporarily disabled AVG to install your program. It's highly recommended to scan your system with AVG regularly
Thank you. .
That's not a great response… For those of us running (or about to run) True Key, how do we workaround AVG's attempt to kill this program?
I had the sam issue, and then after a succesful install, it alerted again for Luhe.MSIL.D chrome-export.exe in teh True Key applicaton folder tree. Are these false positives, or is Intel serving up contaminated software? Scree shot attached.
Thank you for submitting the sample, Larry. It will be analyzed by our concerned team and will be added to the future updates.
I just learned that Intel True Key is offering a one-year free trial of its premium service for password management and proceeded to download the setup from their site. Running the first setup file starts the download process of another file that, upon an execution attempt, AVG repeatedly stops the process and moves the executable file (SetupPBx64.exe) to the Virus Vault. It identifies it as a Trojan, which sounds about right, taking into account what the service actually does. I disabled AVG Protection to finish the install process, but now I'm wondering if it would give me any problems in the future with this particular application. What do you think?
Thanks for reading!
Hello Juan,
Thank you. .
Hello Brian,
It is recommend to keep AVG active while installing any application in your pc. If you are sure that True Key is trusted application then you can add it in exception list. Please follow the following link to add the application in exception list http://avgread.me/18WB2dg .
