Avg remote pc control
Hi Michael,
I regret for the inconvenience to establish the remote session.
Logmein rescue is an applet and is not installed on your PC, once the remote session is completed, you can delete it from downloads folder.
I request you to follow the steps provided in the email to start the remote session to fix your issue.
hi there
i installed the avg remote pc control program because of a problem with my computer and the avg clear program.
my problem was is that once i connected to one of your technicians his name stated with the latter m.
and he didn't reply to me at all for a good 1 or 1.5 minutes and i just closed the app.
i connected twice to the program to the same guy and he didn't reply at all meanwhile my pc slowed down very much so i closed the remote control.
and i have a question- how do i remove completely the remote control program once everything is fixed
Hi Michael,
