Avg running 32 bit on 64 bit pc
Hi Marius,
I would like to inform that it is the expected behavior by AVG installation files, it will automatically detect the bit type of your PC and install it accordingly.
We have also informed the same when you contacted our technical chat support.
Let us know if you need further clarifications.
I have a 64bit system yet task manager shows I am running the 32bit version of AVG.  Spent an hour with online support who uninstalled and then re-installed the 64 bit version - task manager still shows AVG 32bit.   Does anybody have "64bit" shown in task manager?
Hi Marius,
