I am using AVG TuneUp and I started a thorough scan of my laptop almost 2 hours ago…it is scanning and repairing the C drive but it has NOT budged from 13 percent, wont move at all so not sure what to do here would appreciate any help thank U
Hello Sharen,
We regret for the inconvenience. Could you please confirm us whether you have installed the trial version of the AVG PC TuneUp program? If so please check whether you have ran maintenance regularly and perform all the necessary actions suggested by the AVG PC TuneUp program? Please provide us with the screenshot so that we could analyze the issue and assist you better. Please follow the instructions on the article http://avgclick.me/getscreenshot to create the screenshot.
I have the same problem, my newly purchased TuneUp is running but performance Pro is stuck ay 9%
Dropbox
Hello Sharen,
Hello David,
We regret for the inconvenience caused. Please have a look http://support.avg.com/SupportArticleView?urlname=Disk-scan-stops-at-27-after-using-AVG-PC-TuneUp at this article and we request you follow the simple steps which mentioned in the article to resolve the issue. We keep you informed that AVG performance Scan will take some time to scan your system fully and also it depends upon your system performance and storage capacity. If the issue persists, please try to get connected with us, we are here to help you. Thank you
Hi there it is the trial version…not sure how to take a screen shot but basically it is saying "Scanning and repairing drive…C…13 percent complete" been like this for over 3 hours now…and the little circle thing is spinning so really not sure what to do here…to turn off the computer and reboot it and forget about it because this is crazy no way should it take this long to even move an inch…I did the thorough scan, had never done this before but AVG told me that I needed to do this so figured why not
Hello Sharen,
Have you tried to follow the instructions on the article to create a screenshot? Please try to update your AVG PC TuneUp using the instructions on the article http://avgread.me/1dOZCyT and check whether it resolves the issue.
