Download Instagram Pro (https://instagrampro.net/) Version With aditional privacy and services. It can help AVG user to load instagram in their browser.
It sounds like you’re experiencing a specific issue with the AVG Secure Browser where the sound isn’t playing on Instagram Stories, despite it working fine on other parts of Instagram and in different browsers like Chrome, Firefox, and Edge. This could indeed be due to a bug or an update that affected the AVG browser's functionality with Instagram Stories. A possible solution might be to clear your browser cache, check for any updates, or reinstall the browser. If that doesn’t work, you might want to use an alternative browser for viewing Instagram Stories until a fix is released by AVG.
Instagram Stories are a critical feature for engaging with your audience and keeping your brand top-of-mind. They allow you to share more spontaneous content, drive traffic to your profile, and interact with followers in real-time through polls, questions, and more. To achieve good Instagram Story views, it's essential to post consistently, use interactive stickers, and ensure your content is visually appealing.
While organic strategies are key, another effective way to increase your Instagram Story views is by purchasing them. When I was looking to boost my Story views, I came across Bumplikes. Their service provided the initial push I needed, helping me achieve incredible results. By buying Instagram Story views, I was able to enhance my visibility and attract more organic engagement. If you’re considering this option, Bumplikes is definitely worth checking out.
Hello Maria.
Thank you for reaching us here. We'd certainly look into this and help you.
In order to narrow down the issue, we need to troubleshoot and find the feature which blocking the sound.
Please disable the Ad-blocker on the AVG Secure Browser and check whether it fix the issue.
To disable it, Open the AVG Secure Browser > On the top right, click on the AB symbol and then select the allow Ads on this site or select the Pause.
Hello Muhaamad,
We appreciate your suggestion, If you have any concerns regarding AVG,
please create a separate AVG community post by clicking the link below and post your questions in your own post, so we will check with your AVG account and help you accordingly.
I was wondering if there have been any other people having issues with the AVG Secure browser not having "sound" for Instagram Stories only ON A PC. I noticed On Friday Aug 6/21 that it doesn't work Just for IG Stories. Sound does work on the feed videos and everywhere else. Was there an update that was bugged? and is there a Fix coming? I tried different browsers Chrome, Firefox & MS Edge, they all work fine.
Appreciate your efforts in working towards fixing the issue, Maria.
We'd suggest you to try resetting the browser once & check if it helps.
Thankyou Hari for the response. I went ahead and did what you suggested. There is still no sound for
only the Instagram Stories (on PC). it's very strange that it works everywhere else on the site. I double checked and the site is not muted. It only happens on the Avg Browser.
Hello Veeramani,
I just tried that suggestion. Still no change with the sound.
Thankyou for the reply
Hello Maria.
Hello Dinesh,
I reset the browser, I also uninstalled it and reinstalled it and still no change.
It does say it is all up to date.
I don't have any extension active and Ad Block is completely off for that site.
Also on Instagram when I right click on the tab, the site is not muted.(in case you wondered)
Like I said the sound works completely fine for every website I visit, It DOES work for Instagram "feed" videos… But for some reason it will not work for IG Stories.
As mentioned above when I use it on 3 other browsers it works fine.
Hello Maria,
We are sorry to know that. Have you tried to access insta stories in private mode of AVG Secure Browser?
To open private mode, You need Press Ctrl + Shift + nkey simultaneously when AVG Secure Browser is open.
Please check the status and let me know.
While organic strategies are key, another effective way to increase your Instagram Story views is by purchasing them. When I was looking to boost my Story views, I came across Bumplikes (https://bumplikes.com/). Their service provided the initial push I needed, helping me achieve incredible results. By buying Instagram Story views, I was able to enhance my visibility and attract more organic engagement. If you’re considering this option, Bumplikes is definitely worth checking out.
Hello,
We appreciate your information. We'd like to clarify this for you. If you have any concerns regarding AVG, please write back to us in a separate private message so that we can check and assist you accordingly.
Thank you in advance!
You are welcome, James.
Please do not hesitate to contact us back for further queries with AVG.
Hello Maria,
To fix this issue, we request you to get connected with our additional support.
An email instruction has been sent which will help you to get connected.
If the email is not found in inbox do check on spam and junk folders.
