What should I do about this warning I'm getting? "VPN ran into a technical problem". You asked me for a screenshot of this warning. However, it is not possible to send an attachment with the method you suggested.
Zeki Bol/Turkey.
Hi Zeki,
Thank you for contacting AVG Community Forum. I see you are facing connection issue with AVG Secure VPN. I am sorry for the inconvenience. Regarding your concern, Could you please try uninstalling and reinstalling AVG Secure VPN. Please refer the article below for instructions:
1. Uninstalling AVG Secure VPN (https://support.avg.com/SupportArticleView?l=en&urlname=uninstall-avg-secure-vpn&retUrl=support_android_secure_vpn)
2. Installing AVG Secure VPN (https://support.avg.com/SupportArticleView?l=en&urlName=Install-AVG-Secure-VPN&supportType=home)
I hope this helps resolving your issue. Thanks and keep us updated.
Hi Zeki,
