Hi, I often cannot connect to the VPN and the error code is MR43J8. How can I correct this?
Hello Walter,
We understand that you are facing the VPN connection Stability issue and getting error message.
We will certainly check and help you.
Could you please let us know when you started facing this issue?
Please provide us your operating system name and version of your device.
Here are some things you can try if you're having issues with AVG Secure VPN connection stability:
-Check your internet connection: Make sure your internet connection works when AVG Secure VPN is off. If it doesn't, check your network configuration.
-Try a different server location: Open AVG Secure VPN, click Change location on the main screen, and select a different location.
-Try a different VPN protocol: Open AVG Secure VPN, go to Menu > Settings > VPN protocols, and select a different protocol. You can try Mimic or OpenVPN protocols.
-Disconnect other VPN services: If you're connected to another VPN, AVG Secure VPN might not work properly.
-Restart your PC: Try restarting your computer and then connecting to AVG Secure VPN again.
-Check your subscription: Make sure your subscription is active.
-Try a different network: Try connecting to a mobile network or a different Wi-Fi/LAN connection.
Also, please try changing the DNS and check again: | AVG (https://support.avg.com/SupportArticleView?l=en&urlname=troubleshoot-avg-dns)
If you still face same issue, after trying the steps, please let us know.
Hello Walter,
