AVG SSL connection error (ERR_SSL_PROTOCOL_ERROR)
Hello James, I have viewed your previous post through this link: https://support.avg.com/answers?id=906b0000000D6Cm and found that you got email to get remote support but you refused to get the support and wish to get help only via email. I would request you post you replies on only one of the post so that you will receive your answers faster. Are you getting this issue only on your Google Chrome browsers or for all browsers? Have you installed any AVG Secure Search or AVG Web TuneUp on your browsers?
Hello Hariharkumar!
This solution worked perfectly for me! No more sites getting blocked anymore. Yay! Thanks so much for all the help you and other AVG Tech people have given me over the past few weeks.
Here are some methods you may like to fix your ERR_SSL_PROTOCOL_ERROR code problem.
How to solve ERR_SSL_PROTOCOL_ERROR Code Problem:-
1. Checking Firewall or Local Proxy Settings –
Go to the start menu
Search or go to control panel
Click on the ‘Internet Options.’
A Pop up will open there
Click on the connections option there
Click on the “LAN settings” there
Proxy server configuration information appears under proxy server
That’s it, done
2. Disable Browser Extension –
Go to your Google Chrome browser
Click on the Menu icon “≡” at the top right
Click on the ‘More Tools‘ option there
Click on the Extensions options there
Click on the Uncheck Enabled which you want to disable
Click on Remove to delete it completely
Click on Disable link under the plugin to disable it
That’s it, done
3. Check you… Check out more at; Home - TechinPostERR_SSL_PROTOCOL_ERROR (http://www.techinpost.com/fixed-err_ssl_protocol_error-code-problem" target="_blank)-code-problem
That’s it, done
That’s it, done
3. Check you… Check out more at; Techinpost.com/fixed-ERR_SSL_PROTOCOL_ERROR (http://www.techinpost.com/fixed-err_ssl_protocol_error-code-problem" target="_blank)-code-problem
Hey Balasubramnian, thanks for the reply!
I'd like to first say sorry for splitting my questions up, I didn't think of adding this to my question i had already asked. Second, a reply to your question. I have been getting this on all my browsers not just my google chrome and no I have not installed an AVG Secure Search or AVG Web TuneUp on any of my browsers.
So around a week and 2 days ago I posted on here talking about how just after installing Windows 10, my AVG starting blocking multiple websearchs, webpages, etc. for me. The only way I figured out how to get through to these web pages was to turn off "Online Shield" under "Web Browsing Protection".
The link to my last post is here:
Basically, the last response I got was telling me I recieved an email. So I went checked it and replied to the email stating that I want to resolve my issue through email instead of waiting to talk to tech support online. Alas, I have not recieved a reply since last week. I really need to find a solution to this issue because it is making my computer vunrable to virus online.
Please fix this.
Thankyou, James
Hi James, I apologize for the inconvenience
I will help you with the issue.
Please use this link http://avgread.me/1dVjGAf  to set the AVG firewall in default mode
and then add the Browser to AVG Exception list using this link http://avgread.me/18WB2dg .
Please let us know if this solves your issue, Thank you
Hello Hariharkumar!
