Hello,
We are sorry for the inconvenience caused. We will check and help you to resolve it. Could you please provide the screenshot of the unsecure message received from AVG? So, we can check and help you further.
I can’t connect to any public wifi on my Macbook with AVG. It ‘connects’ to the wifi but shows a ‘unsecured network’ message. It then prevents me from searching anything on google/using the wifi. I don’t think that I have a VPN installed. This issue is definitely to do with my AVG as I temporarily uninstalled it to investigate, and the public wifi worked perfectly. Please help. Thanks.
Hello,
