AVG tab in the corner not closing and taking up WAY too much of my CPU then it used to do
Hello, Mads.
Are you referring to AVG icon in your system tray. If yes, it is usual as AVG services always run in the background to protect your PC from virus and malware. If it is something else, please provide us with a screenshot ( http://avgclick.me/getscreenshot ) of the icon and your task manager showing the AVG tasks.
Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
In my right corner under my proces line there is a small AVG protection tab that i cant close, when i go into my task manager and i scroll a little down i see six AVG "tasks" and the last one is taking 30-40% of my CPU while none of the other are taking any, i then try to close some of them because there are no AVG task in the top, but none of them will close and it just stays there in the corner so whenever i go into fullscreen on anything the tab will always show down in the right hand corner
Hello, Mads.
