AVG TAP Adapter c3 error code = 22
My in-built camera is not recognized in my laptop (surface book 3) since I upgraded to AVG Driver update and let it run updating 'out to date' drivers. Unfortunately I uninstalled the software not knowing the updates that caused the problem would still be there.
I ran my surface diagnostic toolkit and found the problem called AVG TAP Adapter c3 error code = 22
The suggested as possible causes:
Mssing drivers or firmware
Ou-to-date or incorrect driver or firmware
Physical hardware malfunction
The advice was to ensure updates were in place. I followed this and still did not resolve the problem.
I would like to know how can I remove this update so I can make my camera work again
Yeni
Hello Yeni,
We're sorry to hear that you're facing this trouble, we regret the inconvenience caused.
This is not the expected behavior of the AVG program.
We will certainly look into it and help you.
AVG Driver Updater allows you to restore individual drivers to their previous version. Follow the steps below to first identify which driver has caused the issue on your PC, then restore the driver to its previous version. If you are unable to identify the problematic driver, we recommend following the Windows System Restore instructions.
We'd recommend you revert the camera driver and check the status.
Troubleshooting issues after running AVG Driver Updater
Keep us posted.
If you face any technical difficulties or need more assistance, please let us know, we will help you with the additional support.
