AVG TAP Adapter v3 Unidentified Network
Hi Kevin,
Thank you for reaching us and we'll certainly help you further.
I request you to disable VPN service and check if you're able to access internet.
Also, I suggest you to change different optimal servers and check if the issue persists.
We request you to share us the screenshot of the error message to check further.
You can post the screenshot here in your topic. Click on "Answer" & then click on the "Image" [mountain symbol] & follow the instructions.
How do I establish a reliable wireless connection for my HP laptop through the AVG VPN software? I have used AVG VPN for about a year without problem.  Now, the "invalid IP address error" has prevented my connection to the internet several times during the past two weeks? Have tried the netsh winsock reset route without luck today.  That method had worked about week ago.
Hi Kevin,
