AVG Tuneup & 1 Click Maint problem
I had Windows 8.1 on my Laptop but upgraded to Windows 10! Afterwards I bought AVG Tuneup & also loaded 1 Click Maint. I now find that I cannot open either program and popup messages comes up as (Missing file TUBasic.bpl & rtl190.bpl) "The program can't start because TUBasic.bpl is missing from your computer. Try installing the program to fix this problem". The same message comes up for "rtl190.bpl"
There are quite a lot of sites from where I can download but I am not sure if it is safe to do so and from which one
Regards,
Johan D du Toit.
Hello Johan,
Sorry to hear that. I would request you to follow the below mentioned instructions to reinstall your AVG PC Tuneup program
1) First step is to use AVG Remover tool and uninstall your AVG PC tuneup program completely. To download AVG Remover Tool please click on the following link: http://www.avg.com/filedir/util/TuneUp_Remover.exe
Hello Johan,
