AVG TuneUP and 1-click maintenance
Hello Debra. I would request you to follow the below mentioned instructions:
1) First step is to use AVG Remover tool and uninstall your AVG PC tuneup program completely. To download AVG Remover Tool please click on the following link: http://www.avg.com/filedir/util/TuneUp_Remover.exe.
3) Your computer will be restarted automatically. After the restart, AVG Remover will finish the uninstallation.
To download, install and activate AVG PC TuneUp program please follow the instructions mentioned in this link: http://bit.ly/1ERJxSd.
Please feel free to contact us again should you need any further assistance.
My AVG TuneUp has stopped working . Everything I try fails. Error box says it has stopped working .Account has been active for 6 mo.  exp.12-2015. It will not let me use any of the maintenance tabs.
