AVG TuneUp Installation Problem
Hello Daniel,
I will assist you further with the installation.
Are you trying to install the trial version of AVG PC TuneUp?
If yes, try click on this link https://support.avg.com/SupportArticleView?urlname=Install-TuneUp to install the AVG PC TuneUp.
If you get any error message, share us the screenshot of the same to assist further.
Please check if you have any older version of AVG PC TuneUp installed on your computer. If yes, please remove the same and then install the latest version of AVG PC TuneUp.
Hello Daniel,
User-added image
I can't install it, it keeps showing this error
