AVG Tuneup problem
Thank you for letting us know, David.
If you need anything else, do not hesitate to let us know.
I have been unable to access any of my Microsoft Office 2013 programs or DropBox for the last five days. I have checked for registry problems and uninstalled latest MS updates in case they had caused a conflict but no difference. If I click on any of the MS programs or files I get the message That the application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command line sxstrace.exe tools for more details. I have realised that these are the same and only programs that I have let Tuneup sleep until required. All other programs work as normal. I tried to open AVG Tuneup from the desktop icon and find that that is also unavailable with the same message as above headed by C:\ProgramFiles\AVG\TuneUp\Ul.exe. Searching the Event viewer also shows errors on the Sidebyside link relating to AVG TuneUp.
I need to get these programs back urgently as I use them in publishing a monthly magazine.
I have of course done the necessary scans which show no problems.
Hello David,
This isn't the expected behavior. We will help you to resolve it.
In order to analyze the root cause, we request you to get connected with our additional support.
An email instruction has been sent which will help you to get connected.
Hello David,
Thanks for very prompt response and to your technicians who sorted the problem. Up and running again.
