AVG TuneUp Registration Problem
Yes, Gregg.
Your PC Tuneup is valid till 2019.8.8. Let's check with the issue. Could you share the screenshot http://support.avg.com/SupportArticleView?urlname=Create-screenshot of expire message you received & have you activated AVG PC Tuneup using your Full License number?
Yes, Gregg.
Hi, I recently bought AVG Anti Virus and AVG TuneUp on line.
I have repeatedly been asked to register the TuneUp part of my purchase.
Each time I have tried to register, it informs me I have already registered this product.
Now it tells me I have 0 days left to register and I no longer have AVG TuneUp on my computer.
The Anti Virus works fine, and I registered both on the same day.
Now getting very frustrated with this problem.
Any help would be gratefully received.
Thank You.
Gregg, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Thank you all for your prompt responses.
Having contacted my product supplier, he gave me the relevant information I needed.
Now all working fine.
Thank you once again for your help.
Regards
Gregg
You are most welcome.
Glad to know that your issue has been resolved.
Have a nice day!!!
