Hello Anthony,
Regret for the inconvenience caused. You may not be able to enable Turbo mode if you have not configured it yet. Please open AVG PC TuneUp, click on All functions. Under "Computer" component, click on Settings (clog wheel) next to "Turbo mode" and follow the instructions on your screen to configure it.
After it is finished, you must be able to turn on Turbo mode from main interface. If you are experiencing issue even after configuring the settings, please try to repair AVG PC TuneUp. To repair your AVG please follow these instructions:
Go to Start -> Control Panel.
Select AVG PC TuneUp in the list of programs.
Select Repair.
Restart your computer.
Avinash,
I have tried your answers and I still have the same problem.
Thanks,
Tony
When I attempt to turn on Turbo Mode, I receive a message stating that there was a problem with turning Turbo Mode on.
Thanks,
Tony
Anthony, Thanks for trying. In this case, I would request you to follow the email steps to get in touch with our technical support team. They will help you to resolve the issue without any hassle.
Avinash,
Thanks,
Tony
