AVG Ultimate Multi Device
Hi Malcolm,
We are here to help.
Yes, the products purchased from the reseller wont be visible under your AVG MyAccount.
You can check the number of devices used from the AVG Internet Security program.
AVG Internet Security -> Menu -> My Subscription -> Near the expiration date
For detailed information you have to get in touch with us.
Unfortunately, you can't check which devices the program has been installed from your program/ account.
The device will be counted individually for the programs.
Thank you for understanding.
I have purchased a license key from a reseller, I've seen from another post that you can't now link this to your account. How can I check which devices I have this linked to and how can I remove devices in the future?
Also does is the multi-subscription per device or per software installation? I have only used on two devices, but have installed VPN and cleanup on my mobile, so will this use three licenses?
Malcolm
Hi Malcolm,
