Hi Russ,
I will help you with the installation of AVG Ultimate on your Android device. We understand that you want to reactivate the AVG products on your mobile device. We are glad to help you with the request.
Please follow the steps below to activate the AVG Anti-virus PRO and AVG Cleaner PRO using Ultimate package :
1. Device Menu -> Settings -> Apps/Application Manager -> AVG -> Uninstall.
2. Restart your device once.
3. Open Google play store app on your device.
4. Search for AVG Anti-virus and AVG Cleaner.
5. Locate and install the free version of the app.
6. Now open the installed app.
7. Tap on the drawer (3 lines) on top-left of the app and select Login option.
8. Enter your My Account email address and password.
Now, the AVG Anti-virus and AVG Cleaner will upgrade to PRO.
If not, please wait for 24 hours and check whether its upgraded to PRO.
Hi Russ,
According to the selling notes the partsof my AVG Ultimate can be used on my Android phone but how? If I download protection or clean up from google store I get advertisements and there doesn't seem anywhere to register that I subscibe to AVG Ultimate
