AVG Uninstall problems
AVG Free has put 16.1gb!! of files onto a small tablet/computer with only 20gb of memory and is causing massive problems.
Neither the standard Windows uninstall or the AVG Remover are working.  AVG remover says it cannot see any active AVG on the computer which is clearly incorrect as there keeps popping up AVG notifications saying software needs updating.
Also when just trying to delete the files, it says don't have administrator rights,
Help greatly appreciated
Hello Mark,
I request you to run AVG clear tool followed by AVG removal tool as mentioned in this article: https://support.avg.com/SupportArticleView?l=en&urlName=How-to-troubleshoot-issues-after-upgrade-to-the-latest-AVG-antivirus-product to remove AVG traces.
NOTE: If there are no AVG program found, click on "Run Anyway" to proceed with the removal.
If you still find AVG folder on C:\drive–>Program Files then delete it manually.
Feel free to contact us if you need further assistance.
