AVG Unlimited HELP PLEASE
Layne,
Do you mean your AVG says it is not installed on the PC when you check it from an android device but you have AVG installed on the PC? It could be an issue with the user interface of AVG on your windows PC. Please try to run repair installation of AVG protection on your PC once and then check if the issue is resolved.
To repair your AVG please follow these instructions:
Go to Start -> Control Panel.
Select AVG Protection in the list of programs.
Select Repair.
Restart your computer.
Please, feel free to let us know if you require any further assistance. Thank you.
I just renewed my subscription with the purchase of the new avg unlimited via retail. After install on my PC I have a couple issues that dont seem right. First, when I open avg zen and navigate to internet security, the menu, minimize, and close link do not function. Second, I look at a connected device (android) open zen and it shows avg is not even istalled on the PC in my first issue. WHAT IS GOING ON???
Layne,
Select Repair.
