Version Number: 16.151.8012
AVG Framework: 1.143.2.51391
AVG Setup Version 1.143.2.51391
System is
Intel(R) Core ™ i7-4770k @3.5GHz
31.94GB RAM
Windows 10, 64bit, Version 1703 Build 15063.13
Let me know what else you may need.
Hello Paul,
We regret for the inconvenience. Could you please let us know what version of AVG program you have installed in your computer to assist further?
My PC started Running super slow. I opened Task Manager which showed that AVG was using 99% of my drive. I opened AVG and saw no scan running. The only other process running that was using the drive was MS Edge trying to clear the cache, but it had to wait until AVG was done hijacking the drive. Took almost an hour. What causes this and how do I stop it?
Hello Paul,
Hi Paul,
I understand your concern and It seems that you are using the AVG 2016 version. To fix the issue I will suggest you to uninstall and re-install the AVG free Version.
If you need any further assistance, please feel free to contact us. We are always here to help you with your issue.
System is
31.94GB RAM
