We acknowledge your refund request, Sinan
And we apologize for the inconvenience caused.
As per your request, I have initiated the refund for the AVG Secure VPN.
The refund will be returned to the payment method used to make your purchase within 5 business days.
I've tried different countries locations but still the same problem persists. I used a different vpn, they can be entered normally
I would like to request a refund for AVG Secure VPN, I would like to request a refund of the product and a refund of my payment.
merhaba avg vpn bağlanmak için programı açıyorum ve her seferinde programa bağlı gibi görünüyor, ancak bir ağın intenet erişimi olmadığını söylediği gibi herhangi bir şekilde bağlanmıyor.
Hi Sinan,
AVG Support via community forum is available only in English. For a translation, you can use https://translate.google.com
Please confirm if you are experiencing this issue with your PC or mobile device, as you have submitted your concern to our AVG mobile team.
If you're experiencing it on your PC, kindly share us the screenshot of the message to check further.
You can post the screenshot here in your topic. Click on "Answer" & then click on the "Image" [mountain symbol] & follow the instructions.
Sinan, thanks for the screenshot.
Please try connecting to different VPN location and check if you experience the same.
Also, check if you have installed different VPN service on your PC.
Keep us posted.
Thanks for checking, Sinan.
To check this further, I have sent an email to connect to our remote experts.
Please check the email and follow the instructions to start the remote session.
I removed the other vpn application and still have the same problem on both pc and android device I tried all the locations but the program seems connected but the connection is still not available
