Unable to connect had VPN since July, didn't notice till now. tried all solutions provided in FAQ as well as DNS server guide.
Hi Lewis,
We will help you to get this issue resolved.
Have you tried to uninstall and reinstall the AVG Secure VPN program to check with the issue. If not please try to uninstall and reinstall the AVG Secure VPN application.
Also share us the screenshot of the error message to check and assist you further.
Thanks,
Vishnu Vardan
Lewis, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hi Lewis,
Thanks,
Vishnu Vardan
