Hello HD,
You've reached the AVG community support forum.
We apologize for any inconvenience this may have caused you. It seems that AVG Internet Security may be affecting your internet speed. We sincerely apologize for the inconvenience and kindly request you to try disabling AVG Internet Security to see if it improves your internet speed. For instructions on how to disable AVG, please refer to the article provided: "Temporarily disabling AVG AntiVirus protection".
| AVG (https://support.avg.com/SupportArticleView?l=en&urlName=disable-avg-antivirus&q=temporarily+turning+off+AVG&supportType=home) .
Additionally, we kindly ask you to ensure that your AVG program is up to date with the latest patches. To do so, please open the AVG program and click on the refresh icon located beside the virus definitions at the bottom left corner. After a successful update, please restart your computer and check if the issue persists.
Thank you!
Hello.
avg web shield slows down streaming speed to around 21 mbps which causes lag and buffering whenever im trying to watch certain 4k HDR content.
i tried to repair avg but other than that i dont think there are any settings to fix this.
Is there anything i can do besides turning off web shield?
Hello HD,
Thank you!
