AVG Web Tuneup uninstallation problem
Hello Reuben,
We kindly request you to follow the instruction's on the article http://avgclick.me/uninstallAVGtoolbar to uninstall the WebTuneUp program from your PC.
I've done this step but was unsuccessful.
I had to re-install AVG due to an add from PC Tuneup that kept appearing. Currently, I've uninstalled everything successfully except AVG Web tuneup which doesn't uninstall in the Control Panel. Thanks for helping!
Hi Reuben,
We regret to hear about the inconvenience caused. Please reboot your computer is Safe mode, click on the below link to show how to reboot in safe mode : http://avgread.me/1JwmD6g
Please go to the C drive and look for a folder  "Program files (x86)", delete  "AVG Web TuneUp" folder. Go to Start -> Control Panel.
Select AVG Web TuneUp in the list of programs.
Click on Uninstall.
If you still see AVG Web TuneUp, please run AVG Remover tool in Safe mode : http://files-download.avg.com/filedir/util/AVG_Remover.exe to remove AVG traces using AVG Remover tool.
Please, feel free to let us know if you require any further assistance.
Hello Reuben,
We regret for the inconvenience.
Please use this link http://files-download.avg.com/filedir/util/AVG_Remover.exe to remove AVG traces using AVG Remover tool.
Hi Reuben,
We are sorry to hear that, could you tell us if you have received any error message while trying to remove the AVG Web TuneUp?
Hello Reuben,
I did but the program still shows in my Control Panel.
I don't understand. Do I delete Program files (x86) after I've started safe mode or are they 2 separate solutions?
Thank you. I'll keep in contact if I have further enquiries.
Hi Reuben,
We're sorry for the confusion, please do not delete the "Program files (X86) folder. Please follow the below instructions:
Please go to the C drive and look for a folder  "Program files (x86)", in "Program files (x86) folder, look for "AVG Web TuneUp" folder. Delete  "AVG Web TuneUp" folder. (Do not delete any other folder)
Click on Uninstall.
If you still see AVG Web TuneUp, please run AVG Remover tool in Safe mode : http://files-download.avg.com/filedir/util/AVG_Remover.exe to remove AVG traces.
