AVG web tuneup WILL NOT uninstall
Hi Avinash.
Thanks for your reply.
I have tried deleting folder and they wont delete.
I have tried everything I know, and all the tools I have read to use from your site. (AVG)
The reason I put multiple topic listing is so you would know what I have already tried and not wasted any time telling me to do these things.
So, I still need a you to provide me with a solution to remove this from my computer.
Regards Roy
Hi Avinash.
Regards Roy
Hello, Roy.
I would request you to remove AVG Web TuneUp folders manually and reboot your PC. If you need any help with it, please let us know the version of Windows OS that you are running.
Hi can you please provide information as to how to remove AVG web tuneup from my system.
It will not uninstall using my computer.
It will not uninstall using AVG remover.
It will not uninstall using AVG Clean tool from safe mode.
I have used all these tools and restarted my system over 15 times now.
Hello, Roy.
William, have you tried the steps mentioned above and checked if you are able to uninstall AVG Web TuneUp from your computer?
